Hi, I am trying to use the sun command but it gives me an error message saying that the sun command isn’t supported by the current render plug-in. I’ve used it before but for some reason it doesn’t want to work anymore.
Hi Lorenzo - what renderer is set as the current one? (render menu > Current renderer) Set it to Rhino Render and you should get some action from Sun.
I’ve tried setting other render settings but I get the same pop-up message. I could be doing it wrong though. What are the exact commands to change the settings?
Hi Lorenzo - If you want to do this via a command and not the Render menu > Current renderer, use SetCurrentRenderPlugIn
> “Rhinoceros”
Thank you. That solved the problem.
