Render problem with geometry
Hi everyone!
I have a problem with these circles when I render the scene. While inside rhino render mode the geometry is fine:
V-ray shows the final result like this:
The curret pattern is produced with grasshopper. Does anyone know what can I do to solve this problem?
Hi
Are those circles a texture or actual geometry ?
would it be possible to isolate only the circles from your GH definition and post it or a screenshot of it here ?
They are just surfaces.
and the full definition is here
KVL_definition-pattern_MK.gh (30.0 KB)
Thanks for the file.
However the definition requires some input curves. I used flat rectangles to simulate, but I’m not sure if that is the correct way.
Anyway. There isn’t any problem when render the baked geometry. But I guess that is due to setting wrong curves.
Also the number of circles seem enormous. You can use the V-Ray instancer to efficiently utilize the renderer.
Could you by chance upload the .3dm you pick the curves from ?
