Render panel does not show Render info
When selecting Render Properties in Rhino Beta for Mac I selected Render Properties in the render possibilities and the window opens empty. It is necessary to select something else then reselect Render Properties to have the parameters.
Hi Joe -
If I’m reading that correctly, you are clicking on “Render” on the top menu line, and then picking “Render Properties…” at the bottom of the list. Is that correct? Can you post a screenshot of what the “Settings” dialog looks like at that point?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Yes.
SysInfo.txt (5.2 KB)
Hello Win,
Any news on the render panel problem?
Joe
