Render only License
Hi, I do a lot of modeling, and a lot of rendering (animation) I cant do any modeling while my workstation is tied up rendering. Would it be possible to have a “Bongo render only” license so that I can use a second workstation to do the rendering while I continue modeling on my first workstation ?
This would work similar to Autodesks 3DsMax Backburner
For something like this you can disable the Bongo plugin on the machine you want to model on and enable it on the rendering machine. Then when you render is finished and you want to go back to animating you can flip which machine has it enabled.
Thank you Joshua,
I will give it a try.
Cheers,
Mike
