I would like for the moment to use render mode for materials and transparency only, without using any light options. The problem is that all becomes very dark. is there a way to view render mode same way as shaded mode from the light view of point?
You’d need to change the material used in a copy of the Shaded mode to do this. Here’s a display mode you can import into Options>View>Display Modes TextureShaded.ini (11.5 KB)
This is a Windows Rhino question right?
Thank you very much Brian !!
Yes, this is a windows Rhino.
I appreciate your help very much !!!
Hi Brian
I have a new computer, and I would like to install “Textureshaded.ini” again, but the above one can not be activated.
Can you please send updated link?
Thanks
Rachel
