Render mesh question
For a Shrinkwrap tutorial, I try to understand how Rhino works.
The following questions are about Rhino and not about Shrinkwrap:
When a closed box contains a lot of internal objects, is it correct that Rhino also automatically generates the render meshes for the internal geometry?
When I open a SaveSmall file, does Rhino then generate automatically the render meshes for all existing objects? Or only the visible objects in layers that are turned on?
And when I only link a SaveSmall file as a block to Rhino, does Rhino behaves the same as the answers of the above questions?
Hi Gerard,
Render meshes are made per object, whenever that object needs to draw in a shaded or rendered viewport. Rhino doesn’t check whether other geometry is blocking the view, so yes, objects inside a closed box still get their render meshes as long as their layer is on and they aren’t hidden. Being enclosed doesn’t exempt them.
SaveSmall just strips out what Rhino can regenerate (render meshes, analysis meshes, the preview image), Pascal explains it here.. Save small still saves HDR environments. On reopening, the meshes are not all rebuilt up front, they get generated on demand for whatever actually has to be displayed. So as far as i know objects on layers that are off (or hidden objects) are not meshed until you turn them on, and if every viewport is in wireframe nothing gets meshed at all until you switch to a shaded mode.
A linked block should behave the same way, the definition geometry gets meshed when an instance needs to draw in a shaded view, not at link time. i’ll run a quick check on the off-layer and linked block cases to confirm and follow up if anything differs.
Hi Japhy,
Thank you very much for your explanation. This is a very valuable confirmation to understand how Rhino works and how to optimize Rhino for large sceneries.
