Render Display Options/Settings
Hi Rhino team,
I can’t work out why the render display is different between CAD files. EG: a stainless steel bolt rendered in one open file appears different to the same bolt with the same material in another open file.
I exported /imported render display settings and it didn’t change the appearance of the bolt, so suggests there’s something outside the standard display options.
I use a material library so I know the material settings are the same.
When I copy/paste from one model to another the appearance changes, and I can’t work out why.
EG: This is the bolt in one open model, I like this appearance.
and this is the same bolt in another open model.
(not sure if those images uploaded correctly)
Can you tell me what to do to fix?
Much appreciated.
Apologies guys, I just worked out the cause, for anyone who has this issue, it’s this check box below.
