I have had a few models lately that after a few days of working on them, flamingo nxt begins rendering the wrong view. I’ll have my perspective view either hightlighted/active or even maximized, but Flamingo will latch onto a front or side view only render that one. I have selected other views and it will only do the same one. The only solution I have found is to set all of my views (or at least Flamingo’s chosen one) to the same named view as what I’m trying to render.
Do you have a file here where this happens that I can see to try and reproduce the issue. Also what versions of Rhino and Flamingo are you using?
Assuming you’re using Flamingo nXt 5, the Flamingo control panel>Render Options has a ‘viewport to render’ drop down menu. This would be good to check against what view you’re trying to render if you haven’t already.
I’m running 3.1. I have 5 installed, but haven’t made the switch due to a handful of issues when working with Rhino materials and Flamingo materials built in previous versiosn. We build stores and it’s a lot bigger project than it sounds to get everything up to date and switched over… but that’s for another topic.
I have solved things at least temporarily by copying all of the 300mb model into a new blank document. However, my viewpoint to render in the Flamingo NXT Control Panel was correctly set as active view for both my old and new model.
