Anyone know if there is a way to change Background Display properties from “Use Render Settings” to “Use Application Settings” as shown in the image but by code using rhinocommon?
Thanks in advance.
Thanks in advance.
Hi Henry,
From within RhinoCommon, no not currently.
If you are familiar with the C++ SDK, the control you’ve referenced controls the CDisplayPipelineAttributes::m_eFillMode
property.
https://mcneel.myjetbrains.com/youtrack/issue/RH-38427
– Dale
Thank you Dale!
Best Regards
