I think the problem here is self explanatory.
Please describe the situation, what youâre trying to do, and what youâre seeing that isnât right.
Assume you are describing a problem about a tool that the reader does not use.
Renaming a saved view, the text field is floating miles below the saved view. Itâs in the picture.
Iâm not seeing that here in the new Mac V6 Beta.
I have the Named View panel in the inspector panels on the right.
When I double click on the existing name in under the thumbnail, the text character are highlighted âin placeâ and I can change them.
Now letâs figure out whatâs different about your setup.
Are you running the new Beta 6.16.19176.12104 from yesterday?
Yes, Iâm using the latest beta. I am running on a MacBook Pro 13" 2018.
I have an external Dell monitor 27" (not the 4k one).
Hereâs a video of it happening. When I click on âview 3â the text field is outside of the extents of the recording.
I have just tried on the built in display on the MacBook Pro and it works correctly so it seems to be to do with using the external monitor.
I donât have a second monitor, but I am running on a 2017 13" MBP.
Please run the SystemInfo command in Rhino when both monitors are hooked up and post those details here please.
Iâll try to find another tech running an extra monitor to see if they can duplicate the problem.
Rhino 6 SR16 2019-6-25 (Public Build, 6.16.19176.12104, Git hash:master @ acb56df4be1a3a80ed6e48097a864a002e5cd136)
License type: Beta, build 2019-06-25
License details: Cloud Zoo. In use by: Robin ()
Expires on: 2019-08-09
Apple Intel 64-bit macOS Version 10.14.5 (Build 18F132) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro15,2
Machine name: Robinâs MacBook Pro
Language: en-GB (MacOS default)
IntelŽ Iris⢠Plus Graphics 655 (OpenGL ver:4.1 INTEL-12.9.22)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 1536 MB
Graphics: Intel Iris Plus Graphics 655
Displays: Color LCD (298dpi 2x), DELL U2715H (109dpi 1x)
Graphics processors
Intel Iris Plus Graphics 655 (1536 MB)
Color LCD (1680 x 1050)
DELL U2715H (2560 x 1440 @ 59 Hz)
USB devices
Seagate: Expansion
Burr-Brown from TI: USB audio CODEC
Apple Inc.: iBridge DFR brightness
Apple Inc.: iBridge Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: iBridge ALS
Apple Inc.: iBridge FaceTime HD Camera (Built-in)
Apple Inc.: iBridge
Bluetooth devices
Nordic Semiconductor:
Broadcom: Magic Keyboard
Third party kernel extensions
com.astro-hq.driver.LunaDisplay (1.0.1) DA36D61E-DF34-3D59-84D2-781A01054D2D
Third party plugins
Rhino plugins
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp âRhinoCyclesâ 6.16.19176.12104
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp âSnapshotsâ 6.16.19176.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp âGrasshopperâ 6.16.19176.12104
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp âPanelingToolsâ 6.16.19176.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp âAnimationToolsâ 6.16.19176.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp âCommandsâ 6.16.19176.12104
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp âSolidToolsâ 6.16.19176.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework âRenderer Development Kitâ 6.16.19176.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp âRDK_EtoUIâ 6.16.19176.12104
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp âDisplacementâ 6.16.19176.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp âIronPythonâ 6.16.19176.12104
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp âRhino Renderâ 6.16.19176.1002
Thanks, I was able to reproduce this issue as well and have filed it as https://mcneel.myjetbrains.com/youtrack/issue/RH-53459
A temporary work around is to right click the thumbnail and choose rename⌠this centers the text field. This only appears to happen if Rhino is on the second 1080p monitor.
Iâm actually using a 2560 x 1440 display, but Iâm sure the issue is the same
