Hello, I’m wondering if there’s a feature that allows you rename certain names of the curves to a different name. For example, if theres curves that has B12_L01, I would like to copy all the curves that has similar name to like C12_L01.
Hello - _SelName
should help - you can use wildcards if you use the command line version _-SelName
e.g. _-SelName "C12*"
If you need to change individual names following some pattern, within the selection, you’ll need a script.
You can try this - it replaces all occurences of text in all object names, no questions asked - it can get fancier.
SimpleRenamer.py (433 Bytes)
To use the Python script use RunPythonScript
, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
