Rename "RunPythonScript" in Undo
Is there a way to set the “RunPythonScript” to a custom string so scripts can be distinguished from each other in the Undo Multiple window?
Undo Multiple
Thank you,
Steve
Hi @spb,
How are you running the RunPythonScript command? From a button?
– Dale
Hi Dale,
I typically use an alias with _-RunPythonScript scriptName in the command macro, but I don’t see a difference when a button’s command contains code.
Hi @spb,
Currently, undo records only record the name the command that was executed. I’ve put in a request for a more friendly version.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43186
– Dale
