Hi all,
I’ve got a small problem with a large list. It’s probably an easy one, I’ve been trying a few alternatives but there doesn’t seem to exist a cull item created to remove values that have an * at the beginning of their value. Does such a component exist or do I have to amend my list before using grasshopper?
That would be a pretty specific component to have. Do you mean you want to remove all entries in a list of text data that start with the asterisk?
That’s exactly what I’m trying to do. Would it be easier if I changed to another value in order to parse them in grasshopper?
Asterisks are harder to match since wildcard notation doesn’t like them, but you can use a Regex pattern instead:
The pattern you need is a backslash (which indicates the asterisk is treated as a regular character rather than its usual special meaning), then the asterisk and finally a dot to represent the rest of the pattern.
Sorry David but I didn’t understand a thing in your first phrase, I had to look up wildcard notation and regex pattern. Did you mean that the asterix is too much of a versitile notation?
You advise me to change my data from “*value” to “*.value”? Sorry if these questions are a bit basic but treating list in grasshopper is definitely not my strong point.
Asterisks are fine, you just can’t use simple wildcard notation (the P
input of the Match component) so you have to switch to RegEx
instead, which is more complicated. But it still works, as the image shows.
ah I found where my error was coming from and it just showed I didn’t undertsand what you meant the first time. I had my panel with *. plugged into the Pattern input and not the Regex…
Thanks a lot David, It works like a charm now.
