Here is the python option, but apparently it doesn’t support arrays for that function.
So instead you will have to do an iteration storing the result of each boolean difference to a variable and using it as Curve A with the next subtracting curve in the next iteration.
The version of the function you’ve shown is obsolete but you may need to use it if you’re running Rhino V5. I’ve used the version of the function that takes a tolerance as a third parameter. I used the document tolerance, you could hard code a value or use an input value if desired.
