Does removing 32-bit Rhino impact to 64-bit?
Also, will it have impact to the WIP?
Just want to save up on laptop diskspace.
Hi Toshiaki - here’s what Brian said in that thread:
"If you uninstall Rhino 5 32-bit, it will likely delete the license file that was created when it installed. 64-bit Rhino 5 will ask you for a license again when you start it, and then everything else should continue to work."
So, up to you…
Thank you pascal, just wanted to check as the thread was a bit old.
V6 i guess only comes in 64bit, so that’s solved too…
