Removing or purging history
Hi there… is there a purge history command or not? (v7)
I can’t work it out… it is referenced occasionally, as either history purge, or purge history… but I cannot find it or the pyramid symbol with the cross over it.
I want to be able to move curves and reuse them in different locations, but I can’t because they were created with history on… and I can’t find a way to remove this history.
Any help? Cheers
The command is HistoryPurge and when run you’ll get asked to select the objects to purge the history from. This is in v7 on Mac as a command name and the toolbar icon is in the History toolbar in the Standard sidebar or you can float the History toolbar from the Window menu > Active Tool Palettes.
