when I run this script the actual material remains unchanged in the edit panel.
Dim arrMat
arrMat = rhino.MaterialIndices
Dim x
x = 0
For x=0 To ubound(arrmat) - 1
Dim matName
matName = rhino.MaterialName(arrMat(x))
Dim arrMatName
arrMatName = rhino.MaterialsByName(matName)
If isArray(arrMatName) Then
rhino.MaterialName arrMat(x), matName & x
End If
Next
Edit - OK, I am seeing the same thing here…
Below is my slightly restructured version, but the basic principle is the same, the material name updates in the layer box, but not in the material panel, and if you save and reopen the file, the changes are also removed from the layer box… Don’t have time to investigate further right now…
Call MakeUniqueLayerMatNames()
Sub MakeUniqueLayerMatNames()
Dim arrMatIndices, i, strMatName, arrMatName
arrMatIndices = Rhino.MaterialIndices
For i=0 To ubound(arrMatIndices)
strMatName = Rhino.MaterialName(arrMatIndices(i))
arrMatName = Rhino.MaterialsByName(strMatName)
If IsArray(arrMatName) Then
Rhino.MaterialName i, strMatName & "-" & Cstr(i)
End If
Next
End Sub
Had the same problem many times in the past. I think RS methods are not completely in sync with RDK materials. Hope it will get all solved at some point. See more info in this thread: RS: Rhino.MaterialName problem
