Removing an invalid object from a block instance
Is there a way to remove invalid objects from a referenced block instance, in order to explode the object (block), via grasshopper? In this case, I am exploding the block using elefont
I am limiting any manipulation of the block in rhinospace (exploding, block edit, etc)
Thanks
Hej R -
Could you post an example with invalid objects?
In Rhino 8, you can use native Grasshopper components to explode blocks.
