Removing all the surfaces from an object
I’ve got a script that uses “Brep.Faces.RemoveAt” to delete surfaces from polysurfaces…and I just relalized, how do I identify and handle if I’ve up and removed all of them? If I use doc.Objects.Replace to update the model with an empty Brep…that’s gonna be bad? I guess I can tell by the length of the list of Breps if I’m about to delete the whole thing…?
A brep without any faces is probably not valid, and replacing with an invalid brep will probably fail. But try it out, see what happens :wink:
Yeah it didn’t generate any sort of error, so that seemed bad, I decided to check if I was about to remove everything and use Delete instead.
also check this older post:
