thanks for reaching out! sorry could you maybe edit the script and do a screenshot? because i am rather new to grasshopper, i am not so sure about the logic behind the components…
Kangaroo “dupLn” drew error of data conversion failing because you supplied polylines instead of “Lines” to L input.
Try to use “Explode” component before “dupLn”.
Would need help over here. It seems like in the tutorial , with the “PCen +Scale component” it could create an offset of the voronoid pattern. However, in my script, when i scale it, it doesn’t offset rather the lines that form the coronoid pattern get shorter or longer.
The tutorial might be using a older version of grasshopper. As on my grasshopper, the “PCen” has more elements like the “Cv , Ce, Ca " instead of just " Cv, Ce”. And also i have bubble saying " area centroids of non-closed polygons…" i am surprised the tutorial didn’t have this.
Screenshot from the tutorial:
Oh yea, i will resolve that from the tutorial later. as im following the tutorial. from the gh file you attached, i just added the next few components to try to loft the poly lines, however, the points create a strange kind of triangulation and i can’t get a smooth surface loft across the poly lines.
