I can reproduce the same behavior in both Rhino 8 and the current Rhino 9 Beta.
After loading my saved Window Layout, the toolbar container is restored correctly. However, after restarting Rhino, the toolbar tabs I deliberately removed are added back to the container.
The tabs being restored are: Standard, CPlanes, Set View, Display, Select, Viewport Layout, Visibility, and Transform.
Reloading the saved Window Layout removes them again, so the layout itself appears to be saved correctly. The tabs are added back specifically during Rhino startup.
This looks related to RH-84019, although that issue concerns deleted containers returning after restart, while here the container remains and its removed toolbar tabs are restored.
@CallumSykes - I can reproduce this in Rhino 9 Beta as well.
Integrated accelerated graphics device with 10 adapter port(s)
This device is not being used
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
