Remove windows
hi,
could someone please help me to remove the windows that i have in the roof, floor and partition walls?
thanks a lot
Exercise 1 climate analysis-Ladybug.gh (160.0 KB)
Exercise 1 Climate Analysis-Ladybug.3dm (17.1 MB)
Moved to Grasshopper category.
Hi Albert,
Although I don’t have climate studio installed (I have LB Tools 1.5) I think your easiest way is to turn these Breps into Honeybee rooms, so you can have more control over the ratio of your fenestration:
Windows_.gh (172.9 KB)
thanks a lot for your quick feedback . i know that it is easier in honeybee but in my master the teacher forces us to use climatestudio because we are not using honeybee yet so i need the answer for climatestudio
In this case, We used honeybee just to build the geometry, no analysis being done with it.
but i need to calculate the EUI with climatestudio using this components
because i think i cannot mix componeent from different plugins
show me a screenshot with your inputs to the climate studio “Model” Component
thanks for your patience
green point i want to remove so i only want windows around wall but when i connect to scale i dont get anything. i think i am close to the solution but i dont know what it is wrong
Exercise 1 climate analysis-Ladybug.gh (161.1 KB)
I filtered out the openings that are not part of the exterior wall, please take a look
thanks a lot.
i have an error
how can i download group…(white box component)
this one?
i got this error
don’t worry just use this round component:
Exercise 1 climate analysis-Ladybug.gh (161.5 KB)
thanks a lot.
but now i have this problem
this is the same problem i have before but using different script . do you now why i get this problem but you did not.
the middle window is triplicated. the same in the other side
It’s a data tree issue I guess, try flattening the output of the scale:
you should have 8 Total windows
Exercise 1 climate analysis-Ladybug.gh (167.5 KB)
something is wrong with me apologise.
could you check what i am doing wrong please?
Exercise 1 climate analysis-Ladybug (1).gh (169.7 KB)
THANKS a lot it works now. last question
how could i remove the windows that dont have a parent surface? they are 4 windows
i dont understand why i have this error.
it is to practice with different alternatives
COMPARATION.3dm (175.1 KB)
COMPARATION.gh (16.8 KB)
thanks in advance
