I’ve been sent a file that call for two fonts I don’t have. How do I purge those fonts from the file and the call for them?
Hi Nicholas -
If you are going to work on the file with the intention to then send it back to the original source, you could use the Don't show this message again
button on the Missing Fonts
dialog.
If you want to change the annotation styles so that these use fonts that you have, you will find the annotation styles with missing fonts listed in the command history when the file is opened, e.g.:
Command: _Open
Read 2 annotation styles and 2 annotation objects that reference 2 fonts that are not installed on this device.
Annotation styles referencing a missing font:
Millimeter Small 01 / Apple LiSung Light [LiSungLight]
Millimeter Small 02 / Apple SD Gothic Neo Regular
Missing fonts:
Gracias Wim.
