Hi everyone, im trying to separate a group of beams that connect with the columns, from those that not. I tried this definition but although i manage to extract the beams that do touch the columns, i have issues with extracting the other beams without generating a lot of duplicates
Wow that’s really easy and works like a charm. I actually found that if i flipped the matrix and used the “smaller than” component on each of the distances from one line to each of the points, and then used mass addition, I could also create a dispatch pattern. Sorry if it’s not clear.
