Many thanks @HS_Kim for the tip about removing the smaller fields. that helps me a lot
I’m just trying to fit that whole thing into my definition. It’s not nearly as easy as I thought it would be.
maybe you can give me another piece of advice.
where would be the easiest way to insert this rule?
Right at the beginning or better after I’ve moved the fields up?
I tried the second variant, but with my ability, there is quite a chaos when trying to connect the contours
