Remove redundancy
I want to remove redundancy (repetition)… My purpose is to identify the shape of each polyline and later pick each one separatly. In total they are 8 kinds of shapes, so I think what I did isn’t very “professional” for a gh file… I don’t know how to merge them in a minimum possible of steps.
Redondance.gh (20.9 KB)
Can’t look at you file, but I think you have one list with alle different types.
Create set on that list -> member indicies (set to operate on = list; member to search for = set members) -> list item ( member indicies = index; list = list of geometrys)
Now you should have one list with ever type in spereated branches.
Hope I could describe it correct :smiley:
But set operations should do the trick. In the end, you create a list of colors, grafted according to the geometry’s and preview them all at once.
sorry, I don’t understand what you mean :sob:
Always internalize your data …
Redondance_re.gh (24.4 KB)
Btw. I recommend you to have a look at data management. Nearly all of your latest threads are about it. A good place to start is:
http://grasshopperprimer.com/en/1-foundations/1-foundations.html
or as PDF: https://aae280.files.wordpress.com/2014/10/mode-lab-grasshopper-primer-third-edition.pdf
I did internalize data but Idon’t know why it doesn’t work correctly …
