Guys
I need your help,
we imported this shape from Revit. we would like to re-shape the shell in rhino, but as you can see, any single lines have tons of points. there is a way in grasshopper to keep the same shape having fewer points? thanks in advance for any answer
rebuild curve?
nope… if I rebuilt … the shape is going to change.
probably there is a way to " convert" the surface in grasshopper, and have a clean line without millions of points
It’s hard to guess what is the situation about the surface just by looking at your picture. You asked about
… that is indeed rebuilding the curve. Tolerance will lead into a new different shape.
If you describe better your situation maybe better solutions will come.
you right…
