Hi, I’m using Opennest to lay out pieces that will be laser cut.
In an attempt to save on cutting time I’ve set the spacing to zero in Opennest.
But this will create overlaps where the lasercutter could be cutting just once if I can remove the overlaps.
Searched the forum and found this solution: Merge overlapped (colinear) curves to single one?
This works great for polyline curves, but I have them mixed with some closed planar curves.
Is it possible to split a list between the polylines and the closed planar curves?
Or is there another way.
reduce_curve.gh (21.4 KB)
