Remove Output Parameters with the standard C# editor?
Hello folks,
I used these methods to remove outputs
Component.Params.UnregisterOutputParameter Method (IGH_Param, Boolean);
Component.Params.Output.Clear();
I tried to following this discussion
But again when I have a “decreasing” update the popup window appears.
Is there any safety way to remove OutputParams with the standard C# editor?
Probably with some clever use of these?
Thank you!
  Component.ExpireSolution(true);
  GrasshopperDocument.ScheduleSolution(5, ScheduleCallback);
  private void ScheduleCallback(GH_Document doc)
  public override void BeforeRunScript()
  public override void AfterRunScript()
SharedScreenshot2
SafetyOutputs.gh (4.9 KB)
