I am writing a class derived from GetPoint; it adds a command option via AddOption(string, string). Once the caller starts selecting points I want to remove that option as it is no longer applicable. ClearCommandOptions will remove all options, but if this custom GetPoint class is being used by a command that happened to add other options in the command, I don’t want to inadvertently clear those options.
(a) Does this make sense?
(b) Is there a way to delete a single command option or enumerate the current options so I can restore them after calling ClearCommandOptions?
There isn’t a way to remove a single option from a RhinoGet class. Just add your options inside of a while (true) loop:
var show = false;
var showOption = new OptionToggle(show, "No", "Yes");
var gp = new GetPoint();
gp.SetCommandPrompt("Base point");
while (true)
gp.ClearCommandOptions();
var showIndex = gp.AddOptionToggle("Show", ref showOption);
var testIndex = show ? gp.AddOption("Test") : -1;
var res = gp.Get();
if (res == GetResult.Option)
var opt = gp.Option();
if (opt.Index == showIndex)
show = showOption.CurrentValue;
else if (opt.Index == testIndex)
RhinoApp.WriteLine("Test option selected");
continue;
else if (res != GetResult.Point)
return Result.Cancel;
break;
// TODO...
return Result.Success;
That works fine if I am the writer of the command and am adding options. But if I am writing the custom GetPoint class and inside MyGetPoint class I add an option, I have know way of knowing if the caller of MyGetPoint (i.e., the command) added options as well. It would be nice if I could query the MyGetPoint to make sure I don’t do something to them.
