So I’m trying to remove a particular knotline, but I can’t reach it… See picture. The indicator which points out which knotline you are removing is not even close to your cursor. Is this a (known) bug or am I missing something?
Can you get to it in a different view?
–Mitch
In the ‘right’-view the problem is the same. In other views it seems to be less but the perspective is such that I still (almost) can’t reach it. I have been able to delete the correct knotlines but I’m hoping Rhino developers can do something about this.
You will probably need to post an example file here or send it directly to tech@mcneel.com so that they can find the problem.
–Mitch
