Hi guys,
I hope all you had a good christmas
I have two questions:
How can i remove the diagonal? so each 4 points I have plane “rectangular” surface
how can I make that each window can detect a parent face?
Regards
Honeybee-radiance.3dm (185.7 KB)
Honeybee-radiance.gh (166.1 KB)
Use Quadrangulate component after the Delaunay Mesh.
I don’t have Ladybug installed, so can’t help you with your second question
i am happy just if you can help me with the first one. i will really appreciate
+1
In Honeybee, applying Apertures requires the host face and the aperture geometry to be
A- Coplanar Faces
B- Non Intersecting
Otherwise Honeybee will simply Ignore these apertures and move on (which is not good)
Some easy way to generate Apertures.
1- Use the Project component to project openings into meshes, this will insure coplanarity
2- Offset the face boundaries of building faces, this will insure that the apertures are created smaller than the host wall and built on the same plane.
