Remove close points
I have trimmed surface which has a closed curve which contains points in almost same places. The curve isn’t very dense. Is it possible to remove automatically all close points from closed curve? If it`s not possible then maybe tell me how to remove all duplicated points in same position.
Hello- can you please post an example? FitCrv comes to mind but I don’t know if that will do.
Yes, I’ve thought about this but it won`t do exactly that. What about the same position points (duplicates)?
The best would be to have something that will remove all duplicated points from polysurface (trimmed edges, edges (duplicated knots), surface control points) - some kind of cleanup like RemoveNakedMicroEdges. It would be nice to have the same for curves.
I don`t want to change shape only remove duplicates.
Hello- if you post an example curve it’s posiible I or someone can help.
