Remove Bottom Part of a not flat pipe
Hey there!
I am still new to Grasshopper, I have created a form using multipipe in Grasshopper (also with help from very very kind helpers in this forum). I now wanted to cut off the bottom part of the pipe but also after searching through the forum/internet/chatgpt and a lot of trial I didnt manage to do that. The pipe should like that create a Tunnel on a not flat surface or also if the pipe goes further up above the surface, the bottom half should still be cut off.
Since the pipe is not flat on a xy plane this didnt work:
Description2
Also further attempts to slove this problem didnt work:
Thank you already in advance for any help or ideas!
Removing of the bottom half of the pipe.gh (260.1 KB)
For starters it doesn’t look like any of your cutting surfaces completely intersect with your pipes.
etc.
yes, I know that the ends are off, but also there where they intersect it doesnt seem to really work, also in general it cuts quite wierdly and not clean.
Remember this?
Just did a quick test and worked fine here…
gr.gh (9.7 KB)
I tried something similar like this too and it always said “split did not suceed”, also now I tried to do the exact same as you did but also then it says “split did not suceed”. Probably Im just doing something really dumb that it doesnt work, but I cant figure out what…
maybe it’s because there are multiple breps? since there are multiple curves?
yes I did look at that too. But from my understanding this only works if I want to cut everything away under the XY Plane, or well if I would have another plane too. But since my pipe isnt flat I didnt manage to do that? I will definitely have a more detailed look at it again so that I figure out how it could work with a not flat curve too
missing
With code like that, there’s no point in trying to be elegant about this.
Remove bottom half of pipe_2023Mar21a.gh (273.6 KB)
I get the same result using your geometry.
mk.gh (252.3 KB)
hmm well thank you a lot, then it should work for me too, I will check and compare with your one to check what I did wrong. Thank you a lot! have a nice day!
I forgot about that one parakeet component, I’m sorry, I thought I romovved everything. And yeah my code isn’t beautiful I know that. As I said I’m just a beginner. Anyway thank you a lot for still helping me! Enjoy your day!
There are so many ways to do stuff like this.
Remove bottom half of pipe_2023Mar21b.gh (272.5 KB)
