Remote Control Panel (RCP) - Wishes and Feedback
… the heck! Ok now it’s there, but only after going in the cogwheel menu > Show Panels.
And suddenly it’s also in this sidebar menu I used before:
Odd.
The colors seem to be a bit off indeed:
And I fully agree that the panel deserves a good update.
Some more wishes:
  • A published panel (the yellow do-it-all-box in GH) should be editable in the remote panel.
  • Store/restore snapshots of the slider settings (is this possible somehow?)
  • Place a 2d (live) representation of the panel in a layout, for easy documenting of design variants.
Thanks!
Thanks Michael, I hadn’t tried out the Rhino 8 RCP yet. First I couldn’t find it either @Eugen, when I went to turn on the Grasshopper toolbar (after much lag when pressing Show Toolbar!):
This toolbar appeared:
But one can still click here to turn on the RCP it seems (with squished icons):
And indeed the colors are much worse/weird now, must be a bug:
Edit 1: I see that the RCP is under panels (also called Grasshopper, pretty confusing!):
Edit 2: For reference, in Rhino 7 one can turn on the RCP by right-clicking and selecting Grasshopper:
Bump!
I would love to have the editable panel as a single click text field.
Also remote legends would be great! I find that they are really handy used as coloured error warnings.
I was trying to add a drop-down Value List to the Grasshopper RCP recently and was surprised to find it still hasn’t been added. I know the RCP is not in active development, however this is a really basic feature that seems to be missing - I’m hoping that it would be a modest addition that wouldn’t have to wait for GH2.
I completely agree!
RCP would become hugely useful with a dropdown list…the sooner the better.
I’ve been trying to set something up with Human and it works, but only in windows and quite slowly
A way to type info into a panel that has been published would also be a convenient addition. I would probably use it to add User Texts and comments to the object being generated
I would finally also like to be able to select geometry in the Rhino window and apply it to a Geometry node in Grasshopper from the RCP…maybe there is a clever way to do this already, but I haven’t found it yet…
Hi @anders ,
This may not be exactly what you are after but in the mean time you may find this script helpful that I had created to be able to use the RCP to Add/Remove objects from a “selection set” that gets referenced into GH.
This allows you to stay in Rhino and “feed” different geometry into your GH script by interfacing with the RCP only.
Graph Space:
Model Space:
FUNCTION_Create_Selection_Set_Of_Rhino_Objects_From_RCP.gh (6.6 KB)
Another critical RCP panel wish list item is that for published panels, allow them to be collapsible to single line and expandable to “scrollable”
Currently the RCP/Grasshopper Panel will only show 1 line of a multi-line published panel which very much limits what could be helpful information to see.
Unfortunately the Youtrack has been dead for six years, and was assigned to Grasshopper 2 three years ago. So we can probably stop holding our breaths for any Grasshopper 1 improvements :face_with_diagonal_mouth:
Cool this will solve it nicely for me, Thank you!
Now I just have to figure out how to do a drop-down… :wink:
Oh yea, I exhaled awhile ago haha. Looks like you updated the category to GH2 though. Which makes sense.
For that in GH1 you’ll need to rely on scripting / UI work or a plugin that enables this kind of workflow
That wasn’t me :face_with_open_eyes_and_hand_over_mouth:
:eyes:
Have you ever found a way in RH8 to use the RCP with GrasshopperPlayer or as a compiled command in Rhino?
I’ve been updating a definition for Rhino 8 that uses the RCP quite extensively. And while the tweaks to colors are much appreciated (e.g. sliders/toggles don’t look disabled), our industrial designers and myself find that certain RCP elements look a wee bit overly “bombastic”. Specifically, the thick stroke around e.g. slider/toggle boxes and the bold font on e.g. slider/button names:
A thinner box stroke and no bold fonts would be another nice tweak, if at all possible @DavidRutten :folded_hands:
Edit: Just noticed that the stroke color around RCP color swatches still use the grey/disabled look. But maybe that’s intentional?
Edit II: And here’s a link to the unscaled/uncompressed image file above. Seems completely hit-or-miss when Discourse decides to upload the actual original image these days!
This is essential! Several times GH definitions are meant to be used by employes or custumers that can use basic Rhino functions, but are afraid to interact with Gh itself, the RCP helps a lot.
Also We could have the hability to build a the RCP UI, like the plugin “Grasshopper Gold” does using ETO components
Hej Anders -
I’ve thrown this onto the heap so that someone will eventually take a closer look:
→ RH-89587 UI Appearance: Change in RPC Dialog
Cheers Wim, much appreciated.
Edit: Perhaps a path of least resistance would be to enable us to edit the RCP appearance settings ourselves (e.g. via the Grasshopper.Instances.ActiveDocument.RemotePanelLayout namespace). Thereby avoiding the whole “this person thinks this color is ugly, this person thinks is perfect” situation that seems to arise in the GUI topics.
:index_pointing_up:
this would be the most important change.
Sliders which can be scrolled with the mouse wheel and cursor would be nice, actually not only in the remote control panel…
