Remap numbers
Hi;
I’m stuck on trying to remap a range of numbers with “symmetry”. I mean as instance a range from 1 to 10 in such a manner that once remaped goes as follow 10-9-8-7-6-5-4-3-2-1-2-3-4-5-6-7-8-9-10.
I’m attaching here opne of my attemps but obviosly is not working.
Could anyone teach me how to do it ?
Thanks in advance
Joanremap numbers symmetry.gh (6.9 KB)
you can use reverse list
Dear Seghier;
Very clever solution.
Thanks so much.
Joan
Hi Seghir;
My definition is getting more complicated.
I need to play more with the range in a manner that I can relocate the axis of the symmetry to get as instance the following range :slight_smile:
10-9-8-7-6-5-4-5-6-7-8-9-10 or
Do you know any way to play with the range to modify the list depending on the “symmetry” axis and the number of values in the range?
Thanks,
Joan
I have special components for this in Pufferfish called “Mirror Cut Numbers”.
MirrorCutNumbers.gh (9.6 KB)
Hi Michael;
Your component fits on my definition to perfection.
I will make aglance to the other components of your plug in, there are many !!
Thanks so much .
Joan
