Remap numbers limit
Hello!
This is probably something trivial to the code monsters here. My question is the following:
let’s say I trying to remap value a; the source domain is between m and n while the target domain is set between p and q. What I would like would be to limit the remapped value of a, let’s call it b to the value of q even if a takes values larger than n. The same would apply also if a<m; b=p
Thanks in advance!
Hi - I would think that you can use the Graph Mapper for this:
Seems to work perfectly!
Thank you @wim
buuuuut… my promblem is slightly more complicated (maybe I didn’t explain it properly):
let’s say that my source domain is 2 To 3 and my target domain is 0 To 100; while my input slider takes values from 0 To 10. What I am after is a method that outputs 0 whan my slider is in the interval 0-2; outputs the remapped values for when the slider is in the source domain; and outputs 100 when the slider is in the 3-10 range. I could build a small example if it makes things more clear.
You might want “C” output?
Looks like it does the job! I’ll play around with it and I’ll get back to you.
Thank you both for your time.
