[Release] 'byRhinoGen' – Direct AI Rendering Plugin for Rhino
byRhinoGen — AI Rendering for Rhino
byRhinogen-Logo
What is byRhinoGen?
byRhinoGen is a direct, dedicated AI rendering plugin fully optimized for the Rhino 3D environment.
While AI-based rendering has gained massive popularity recently, most workflows require leaving Rhino to use external web platforms, which constantly disrupts the creative process. To solve this inefficiency and maximize workflow productivity, we are thrilled to announce the release of byRhinoGen.
With byRhinoGen, you can now seamlessly bridge the gap between modeling and high-quality AI rendering—all without ever leaving the Rhino viewport.
Quick & Easy Setup
No external downloads or complex installation processes are required.
  • Instant Installation: Simply type the PackageManager command inside Rhino, search for byRhinoGen, and install it right away.
  • Seamless Integration: Once installed, it runs directly within a native Rhino panel, allowing you to leverage powerful AI rendering tools while maintaining your familiar Rhino workspace.
Credits & Pricing
The plugin operates on a credit system, with credit consumption varying based on the AI model selected and the resolution of the generated image.
  • :wrapped_gift: New Sign-up Benefit: Get 20 free credits immediately upon registration! This allows you to test the plugin and generate roughly 5 to 10 high-resolution images.
  • Free Built-in Editor: Even if you run out of credits or choose not to purchase more, you can still use byRhinoGen’s built-in image editing tools for free. Adjust brightness, contrast, shadows, and curve-based enhancements directly inside Rhino.
https://www.food4rhino.com/en/app/byrhinogen?lang=en
byRhinogen-Logo
https://www.instagram.com/p/DZZUxi0iWQT/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
TestShot
  1. Prompt : Make it with a real electric drill image, giving it a commercial/advertisement-like feel. The material and color remain the same., Usage shot of a person actually holding and using the item, white background. (2 Credits)
  2. Prompt : Too much hair on the arms. Please remove it.
    (This image was made using the image above.) (2 Credits)
byRhinoGen 1.0.1 Updates Notes
  • Upscale Ratio Update: Changed the default upscale factor from 4x to 2x.
  • Regeneration Improvement: Automatically selects the most recently generated image as the ‘Source’ after region editing.
  • Queue Usability Improvement: Added a zoom view feature when clicking on queue thumbnails.
  • Queue Thumbnail Bug Fix: Resolved a display error where thumbnails did not match the configured view mode.
  • Result Window UI Update: Added placeholder/guide text to the prompt input field.
  • Encoding Error Fix: Fixed an issue where saved Korean prompts were corrupted in text files.
  • AI Content Labeling: Added automatic ‘AI-Generated’ text overlays and embedded Google SynthID digital watermarks.
  1. prompt : Chairs like wonderful art decorations in an art museum
Test render
byRhinoGen 1.0.3 Update Notes
  • UI Fix: Resolved the issue where the pop-up window was being cut off during login failures.
  • View Settings: Fixed the issue where “Named View” configurations were being ignored.
  • Localizations: Added multi-language support for internal login error messages.
  • Performances: Improved stability to prevent Rhino from freezing when adding multiple items to the queue.
  • Style Prompts: Users can now edit or delete default styles in the style prompt; added a “Reset” button.
byRhinoGen 1.0.4 Update Notes
  1. Credit Usage Adjustment: Due to changes in Google’s API pricing policy, the credit consumption for certain features has been adjusted.
  2. New Model Added: Nanobanana 2 Lite (gemini-3.1-flash-lite-image) is now available.
:light_bulb: We Need Your Feedback!
Just as byRhinoView reached its high level of completion thanks to your invaluable insights, byRhinoGen also relies on your feedback to grow and improve. Please share your thoughts with us!
prompt : Ceramics displayed inside the National Museum of Korea, with people passing by behind them.
NanoBanana2 Lite / 2 Credits
Using byRhinoGen, I created photoshoot-style images of people holding the product using mannequin models, and it actually turns out pretty well
