Relating between Panels and commands
Hello Rhino Developers,
How can I control the command that I am building to the visibility of the panel?
I mean :
while (command is running) → no other commands can run, and then the panel pops up (panel dialog type is Form), if the user closes the panel, the command stops.
thanks
Hanan
This is usually done with a modal dialog box, not a panel.
– Dale
thanks for your reply. I changed it to a dialog box.
You can find an example here
