Regression: Popup toolbar draws outside of the screen
Here’s the toolbar at the bottom of the screen in Rhino 7:
Here’s the same toolbar at the bottom of the screen in Rhino 8:
The positioning of the toolbar is also worse, because it hides the original button.
Also, I really dislike that it tries to squeeze two short, text only commands onto the same line. I want a single column popup.
Yeah, right now the container handling/sizing on both platforms sucks… :exploding_head:
RH-79213 Popup toolbar draws outside of the screen and covers original button
Also, I think you’re looking for the popups to be menus instead of toolbars:
RH-67717 Toolbar: allow flyouts as menus
Can’t see the first one, but the last one is 2 years old… however, the popup menu seem to look the same across both V7 and V8 to me (apart from the size & position).
Hi Robert -
That should be visible now.
