Region intersection problem
As always, thank you Inno, for looking into this.
Not quite, although you did manage to get something out of it (Region Intersection component).
The result(s) around exterior edges of the panel should look like this:
The result(s) where perforations intersect with panel holes should look like this:
Seems like RInt doesn’t like it when one of the input lists contains multiple regions (holes) inside a larger region (panel edge).
I did a test to visualize this matter:
MCXRINT_test.gh (1.5 MB)
Copying something similar to what happens on this topic didn’t give me favorable results either. :thinking:
Thanks - crossing fingers for next aha moment.
