Reflected polygons limitations
Hi All,
Why can’t I insert edges or stitch meshes of any of the sides when the object has reflect applied?
It seems like a bug, isn’t it?
I understand that rhino prevents the edition of the dark side (reflected) but why is it limiting both sides?
Hi Joaquin - yep, it is a bug - https://mcneel.myjetbrains.com/youtrack/issue/RH-81085/InsertPoint-and-Reflect
Hi @pascal, any idea about date for a solution? this issue is annoying.
Hi Joaquin this is actively being worked on - InsertPoint works here, in our builds, there are a couple of other commands similarly affected that are also getting fixes.
