@xkdsofa Looks like an interesting feature but I’m not sure I understand exactly what it is doing. Is it the same as changing the orientation of the reflection plane or is it actually adding new reflection planes along these red lines?
Maybe you could provide a link to the help file explaining the command in this other software?
See the video link here:
https://youtu.be/F7gsGEieeqM
Online documentation
I think I understand now, you would like to be able to modify the reflection plane after the Reflect command has run. I’ve added this as a feature request: https://mcneel.myjetbrains.com/youtrack/issue/RH-65521
I think you will be able to get the same results by selecting the vertices on the parent side and rotating / translating them. Not as intuitive as editing the plane directly, but it’s something.
The added link cannot be opened. Do you want to add it successfully?
The axis of symmetry is a symmetry plane that can be selected, moved, rotated and previewed in real time
Hello- that link should be public now.
