I’m making a script to automate the tagging of all doors in a project, and having a parameter for the site which the door opens would be fantastic.
(current tag tool [I’m talking about “Opening Dimensions with breakline”] does not respect window/door rotation and places them in non-ideal positions… hence the need for the script)
Hi @Kida you can control the position of the tag in relation to the linked object by clicking the “Point” option in the command line, during the vaTag command. But this needs to be set object by object, since the default distance of the tag to the linked object is hardcoded and there’s no user interface for editing it.
You can change the tag Orientation to Vertical or Aligned. Do these works for you? the bad news is that the “Aligned” option rotates the tag in relation to the Horizontal position (we should add a new parameter for the tag rotation regardless of its alignment).
The y-axis of the door/window plane luckily points towards the leaf opening which, with the ability to determine the opening side of the leaf, is exactly what I needed.
