Reference worksession layer
Hi
In Rhino 8, is it possible to reference geometry from a linked model (without importing)? Using the standard Query Model Objects component doesn’t seem to work.
Elefront can do this using their Reference By Layer component.
Hi Paul -
When you link a 3dm file, you are likely inserting that file as a block. If so, you’ll either need to explode that block instance, or get the block definition attributes to get to its layers.
Worksession attached models and their content don’t show up in Grasshopper.
Looks like I only read the body of the post, not the title. Yes, worksessions is something else. Not that that’s something I can test on my Mac here anyway…
I suppose that a workaround for the time being is to link as reference.
