Reference code from rhino plugin in grasshopper?
I’d like to be able to reference class methods & properties in a Rhino plugin from Grasshopper script components. Is this possible?
Found this StackOverflow post from 2016 which looks promising but the example provided (dalefugier/Platonics) is no longer online.
Any help would be greatly appreciated!
Hi @Carsten_Rodin,
A better approach is to have a a utility assembly that is shared by both your plug-in and your Grasshopper component.
– Dale
Ah great, thanks @dale for the speedy reply. Any chance you still have that example available somewhere, or something similar?
Looked like the sample was moved here:
– Dale
Awesome, thank you!
