Refenced curve does not update when changed
See image below:
If I move the control points of the referenced curve (2) it does not update in grasshopper (2). The connection is not live and needs to be re-referenced.
Same with other objects. Is this intentional?
Not intentional, but either I broke it or it never quite worked. I’ll try and get it fixed today.
Ok, thanks mate.
Yeah I broke it when I made curve and surface parameters more flexible a few versions ago.
Next release will have it fixed again.
Fixed and started a new public release build, but I noticed there’s at least two bugs left when it comes to curves referencing SubD edges. That’s not something I can fix without help from the SubD developers, so that will take a bit longer.
Hello @DavidRutten,
thanks for the support,
I would be happy to be able to access basic surface and curve parameters.
