When typing PushPull, the PullPush (unknown) also shows up. It should be removed so that it doesn’t clutter the list.
I suspect this is either from a different plugin or script you use or have used, I am not seeing that here.
Can you run _SystemInfo and post back the results?
Here is the systeminfo:
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Not For Resale Lab, build 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [52% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GT 650M (NVidia) Memory: 1GB, Driver date: 4-9-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 425.31
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce GT 650M (NVidia) Memory: 1GB, Driver date: 4-9-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 425.31
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-9-2019
Driver Version: 25.21.14.2531
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Drakon 1.8\Drakon.rhp “Drakon” 1.8.2408.31
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
D:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
D:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
D:\Program Files\Rhino 8\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
D:\Program Files\Rhino 8\Plug-ins\export_STL.rhp “STL Export”
D:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
D:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
D:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
D:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
D:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
D:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
D:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24254.15001
D:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
D:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
D:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Program Files\Rhino 8\Plug-ins\Displacement.rhp “Displacement”
D:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp “SectionTools”
Can you check if the command is still there when disabling the third party products?
Also check if it is maybe just a (left over) alias.
It looks like it is one of the commands used by some plugins we used in the past with previous versions of Rhino (like RhinoGold). Even though those plugins do not work with Rhino 8 and are not loaded, their commands are still showing…
Are these plugins installed for Rhino 8 nevertheless? It would help to see which plugins are in your list of plugins that don’t ship with Rhino
(RVB) scripts can also add aliases.
Edit: I see RhinoGold 5 had a PullPush command
It was RhinoGold 6.6 for Rhino 6 which was loaded and disabled. After checking “Ask to load disabled plug-ins” this and the other redundant commands disappeared.
Is it possible to prevent a plug-in from loading without asking?
So this is the same as checking off the Enabled box.
Let me rephrase my question: is it possible to block some plugins without asking and to ask to load others?
no, only for all or for none. In case you want to block always and still use that option, uninstalling the ones you don’t want is the only option.
