I am trying to send it to a local makerspace. It says- Files should be in STL format (.stl). The maximum allowable file size is 16 MB . My file says it’s 51.9 MB. This is a component of a larger piece and is only about 3” x 2”.
if your object is an subd the subdivision level below is the important parameter.
0.0001 inch = 0.00254 mm
what 3d-process ?
my guess - the precision is somewhere between the 0.1 to 0.01mm
so maybe set the edge-Distance to some rougher value ? 0.0005 in or even 0.001 ?
I really appreciate all the input- I changed “maximum edge to surface distance” from 0.0001 to 0.001 and my file was accepted.
My object is NURBS and I was printing to a Bambu printer using FDM technology.
I usually send my files out and print using SLS but I was hoping to get a quick turnaround visual model before I order multiples. I have never had to reduce mesh before.
