ReducePointCloud command is simplistic
The ReducePointCloud command removes random points rather than inner points or isolated points. Generally the point cloud describes a surface. Any point which is inner and isolated probably represents random noise. It would be natural to remove these points rather than randomly chosen points.
Yes it does.
https://docs.mcneel.com/rhino/8/help/en-us/index.htm#commands/reducepointcloud.htm#(null)
I don’t think this is accurate.
If you need another algorithm, you might try CloudCompare.
– Dale
You can’t beat Geomagic’s decimation for point clouds or meshes. It’s not cheap but if you are doing this a lot its will save time and improve the quality of result.
It has options to remove outliers, set point spacing (or triangle edge length), curvature sensitivity, set target # of points (or triangles).
